my car just overheated the code p0117 is the only code the car has can anyone help me with wat is it that i need to do
I would seafoam it
1984 GTI project-1984 GLI cruiser-2003 Jetta
This code refers to the engine coolant temp circuit show a low input.
Possible causes--
Harness or connectors (The sensor circuit is open or shorted.)
- Engine coolant temperature sensor may be faulty
- Low engine coolant level.
Possible solution
- Replaced coolant temperature sensor
- Repair connector or harness look for loose plugs or grounds.
