VW Jetta: "Fuel Air Metering" Code P1296|Forum Volkswagen Bora
Results 1 to 9 of 9
Thread: "Fuel Air Metering" Code P1296
    Stunt Status slowjet1.8 is on a distinguished road slowjet1.8's Avatar
    Jul 2010
    Fayetteville, NC
    2,054
    Default "Fuel Air Metering" Code P1296
    I recently threw this code, i did some research on it and from what i could find a lot of sources were saying that it was the MAF sensor, so yesterday i cleaned my MAF and cleared the code. I drove around for 90 miles then i threw the code again. I also am catless so i am curious if that has anything to do with it. I also read that it could be an O2 sensor. I also scanned it with another scanner and it came up with the same code but a different explanation, this time it said coolant system malfunction. I have read to change the coolant temperature sensor. I really need to figure out my problem so i can get it fixed because my car needs inspection this month. Thanks guys.
    Check us out -->Hidden Content
    JettaJunkie.com
    Advertisements
    Jul 2010
    Fayetteville, NC
    2,054
    Default Re: "Fuel Air Metering" Code P1296
    so i think it is the coolant temp sensor. The auto parts store showed up with two different ones, a 2 bar and 4 bar. Which one do i need?
  4. #3
    Jul 2010
    Fayetteville, NC
    2,054
    Bump...
  5. Remove Advertisements
    JettaJunkie.com
    Advertisements
  6. #4
    Jul 2010
    Fayetteville, NC
    2,054
  7. #5
    Jul 2010
    Fayetteville, NC
    2,054
    anybody...
  8. #6
    Box One Collective j-man41 is on a distinguished road j-man41's Avatar
    Jun 2009
    Vancouver, Canada
    1,666
    Try Google-ing around a bit more. When I was researching to fix my cooling system on my VR I'm pretty sure I read somewhere the 1.8 has 2 sensors, one being a 2 prong and the other a 4 prong. If I recall one is at the back of the engine and the other is at the front. But don't quote me on this, like I said, I was looking for info on a VR so was just scanning through the 1.8 stuff.
  9. #7
    Jul 2010
    Fayetteville, NC
    2,054
    Quote Originally Posted by j-man41 View Post
    Thanks ive been searching around alot. i read that the green top, which is a 4 prong fits all mkiv models so im assuming thats the one i need. Thanks for the help.
  10. #8
    Jul 2010
    Fayetteville, NC
    2,054
    bump, changed my CTS, drove about 200 miles light came back on, i already cleaned my maf so i'm stumped, i really hope i do not need a new maf. I might put my cat back on to see if that has anything to do with, maybe the O2 sensor is reading wrong or something.
  11. #9
    Jul 2010
    Fayetteville, NC
    2,054
    up
