pleaseeeee help before i smash something lol.. i need to push the wires/fuse connection for the IGNITION fuse spot back into its place so i can even START THE ENGINE... :X
yes^. there should be 2 torx screws holding it in place. but u'll need to b4 carefully removing it, its tight and many things can go wrong in a hurry lol. mine wasnt that bad, i had mine out to wire my boost gauge.
onavianva you're right. those 2 screws hold the assembly in place. If you take those out you should be able to move the panel enough to put the wire back in place.
Although it may be easier to take the panels off from under the dash too. That will give you some room to get your hand behind the panel for easier access.
any idea why it was messed with in the first place? from a previous owner or yourself?
