Okay so immobilizer is adapted. now i have a whole new set of codes
VAG-COM Version: Release 311.2-N
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 06A 906 032 DL
Component: 1.8L R4/5VT G 0003
Coding: 07500
Shop #: WSC 00066
8 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16685 - Cylinder 1 Misfire Detected
P0301 - 35-10 - - - Intermittent
16686 - Cylinder 2 Misfire Detected
P0302 - 35-10 - - - Intermittent
17704 - Error in Mapped Cooling System (usually temp Sensor or Thermostat)
P1296 - 35-10 - - - Intermittent
16688 - Cylinder 4 Misfire Detected
P0304 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17070 - ECM Power Relay Control Circuit (J271): Low
P0686 - 35-00 - -
17925 - Main Relay (J271): Electrical Malfunction
P1517 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 D
Component: ASR FRONT MK60 0103
Coding: 0018945
Shop #: WSC 00066
4 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
00668 - Supply Voltage Terminal 30
008 - Implausible Signal - Intermittent
01044 - Control Module Incorrectly Coded
000 - -
004 - No Signal/Communication
Idk what to do, helpppppppppp
