VW Jetta: turn signal problems|Forum Volkswagen Bora
Results 1 to 4 of 4
Thread: turn signal problems
    Junior Member speedomk4_2.0 is on a distinguished road speedomk4_2.0's Avatar
    Apr 2011
    amarillo Tx
    3
    Blog Entries
    2
    Default turn signal problems
    i have a 2000 v jetta 2.0 and my turn signal fuse keeps blowing every time i turn on the right blinker replaced the turn signal relay and still keeps blowing what could cause the fuse to blow everytime i turn my turn signal to the right
    JettaJunkie.com
    Advertisements
    Senior Member Sosculero is on a distinguished road Sosculero's Avatar
    Oct 2010
    NJ
    1,573
    Default
    Don't turn to your right duhh !!! Lol im just kidding but on your right signal bulbs...check ALL the bulbs, plugs, and wiring....something is grounding out
    almost forgot to tell u....if u cant seem to find the problem try this test....see if u can manage to get a breaker to replace the fuse....unless u want to burn up 4 or so fuses....but go to every turn signal light and pull 1 out and use ur turn signal. like go to front headlight take the bulb out and use the turn signal....if fuse pops then that bulb + wiring may be ok....go to fender then rear light....its a lil easy test to see if u can rule out the problem a little better. lmk what u find or get
    Sent from my DROIDX using Tapatalk
    2000 2.0 AEG 5 Speed : Swiss cheese intake. Magnaflow 2.25 Catback Exhaust. SOLD! Hidden Content
  4. #3
    Apr 2011
    amarillo Tx
    3
    Blog Entries
    2
    Default Re: turn signal problems
    okay so i tried the bulb thing you said and yeah still doing the same thing you think it could be the turn signal switch
  5. Remove Advertisements
    JettaJunkie.com
    Advertisements
  6. #4
    Oct 2010
    NJ
    1,573
    Default
    U can try to take apart ur steering column for ur turn signal lever but if im not mistaken if it's the same as others.....the jetta should have more into a flat metal contact that transfers electricity to where it needs to go ( ie turn right or left) ...I guess take it apart and search around cuz I've never done it nor have the need to....u never know u may find wires touching each other when u turn right
