Junior Member
got code 17584
anyone know what this code mean 17584 - Bank1: O2S (Lambda) Correction Behind Catalyst: Control Limit Reached?
I think it'll work...
Re: got code 17584
Found on the vortex...
* VW DTC 17584 (P1176) - O2 Correction Behind Catalyst, Bank 1 Limit Attained
It basically means that the post-cat O2 sensor heater element is not working correctly.
Now that could mean the actual sensor is toast and need replacement...
Or the wiring from the ECU to the post-cat O2 sensor is cut / spliced somewhere.
Verify that wiring is good; if so, the post-cat O2 sensor needs replacement.
http://www.westcoasteuroclub.com
I work from awkwardness. By that I mean I don't like to arrange things. If I stand in front of something, instead of arranging it, I arrange myself.
- Diane Arbus
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Volkswagen Forum
Volkswagen Jetta
Diminished Value Oregon
portland oregon seo
oregon accident report
Diminished Value
total loss
Google Places Forum
Las Vegas Myths
Oregon Civil War
privacy policy
