VW Jetta MKIV/MK4: erratic rpm at idle |Volkswagen Bora
Results 1 to 6 of 6
Thread: erratic rpm at idle
    Default erratic rpm at idle
    Hello all I have a 04 2.0 (2slow) other day i got the code p0300 random miss fires changed out the wires and plugs and then the code came back and so changed the coil pack and its better but now when my car is at idle it seems rough and rpm drop 100-200 rpms ( not thounds) but you can fell it so i changed my fuel filter and put new k&n filter in and still has rough idle in park nutral or in drive when stopped. what else could it be? i cleaned the mass air flow sensor but same thing is going on? any help would be great thank you all.
    04 vw jetta 2.0 108,000
    Member c.berardinis is on a distinguished road c.berardinis's Avatar
    Sep 2011
    Ewa Beach, HI.
    89
    Default Re: erratic rpm at idle
    my old audi had the same problem it ended up being a module for the injectors ill have to find the paperwork, but some cars have them individual and some a module (which is more expensive) but when i replaced it, it was fine ill see what i can pull up and get back to you. no guarantees, just going with a past experience.
    Oct 2007
    PA
    2,775
    Try cleaning your throttle body.
    Thanks that will be great if you cant find it I will investagate more into that dont kill yourself trying to find it but if you do that be great. Idk for some reason I do feel like my injectors are loud like I can hear them ticking inside my car is that normal? ive used like lucas injector cleaner then again idk if I believe in that kind of stuff.
    I did not too dirty felt a little better after but not 100% I think ill try again in few days and get a better shot at it I only sprayed a little as I was in a hurry because we got a ems call and had to stop. Will let you know soon if it works after I get a good shot at it thanks for the reply.
    Sep 2011
    Ewa Beach, HI.
    89
    yeah i cant find the name, ill keep looking, but your injectors are not clogged. it's the module that controls the injectors it's on the top of my head and im retarded for not remembering the name but you can just call a vw tech and they will tell you over the phone.
