VW Jetta How To/DIY: DIY: How to Remove 2.5L Engine Cover|Forum Volkswagen Bora
Results 1 to 6 of 6
Thread: DIY: How to Remove 2.5L Engine Cover
    Default DIY: How to Remove 2.5L Engine Cover
    I didn't see a post for the 2.5L Engine Cover so here goes....
    Tools You'll need:
    Phillips Screwdriver
    Slotted Pliers
    Torx 15 Driver
    This image basically shows the points where the cover is attached:
    First Step is to remove the torx screws holding the cover to the air intake:
    Next Remove the sensor connection:
    Use the pliers to release the hose:
    Now to the cover itself:
    You will need to use some pressure to pull the cover from the mounts.
    I pulled up on the lower left corner and it will sort of pop free, like pulling
    a cork out of a bottle. Repeat this with the other corners.
    Finally you will need to wiggle the cover free from the engine compartment.
    There is a down-tube on the back of the cover that requires some work to wiggle it free.
    This Picture shows the back of the cover:
    To remove the air filter simply remove the screws on the back of the engine cover.
    The screws are numbered 1-5 so I removed them in that order
    The filter cover then can be opened as so:
    Question Re: DIY: How to Remove 2.5L Engine Cover
    what a 2.5 engine cover that has no holes for the torx screws
    Default Re: DIY: How to Remove 2.5L Engine Cover
    Ok, going to try this first thing in the morning. I got a K&N drop in filter, wanna try it out with an ECU flash next. Keepin it simple.
    Awww, shucks!! I snapped the front left clip! At least there is a tight enough seal against the seal/surround of the new filter. Should not be a problem.
    BTW, runs like a raped ape for a 2.5 that it! Didn't audi turbo these and get crazy HP?
    Junior Member jettninlv is on a distinguished road jettninlv's Avatar
    Jul 2011
    Las Vegas
    Thank you!! I have had a hard timefinding anything that seems to be geared for the BRAND NEW NEVER HAD A VW BEFORE OWNER!! This is quint essintial info for me since I know NOTHING about my 07 Jetta wolf 2.5!! Any other helpul info or even links would be greatly appreciated!
    Good info. Thanks
