VW Jetta MKIV/MK4: Jetta Auto to Manual Swap Question |Volkswagen Bora
Results 1 to 5 of 5
Thread: Jetta Auto to Manual Swap Question
    Junior Member urbann.nomad is on a distinguished road urbann.nomad's Avatar
    Aug 2011
    Roanoke, VA
    3
    Default Jetta Auto to Manual Swap Question
    Hello Everyone,
    I've researched this question and cannot find exactly the answer im looking for so im resorting to asking.
    I have a 2000 Jetta 2.0 with an auto transmission.
    A guy recently contacted me saying he has a 2003 Jetta Wagon 2.0 with Manual Tranny that was wrecked.
    My question, will it be possible to swap manual tranny from this '03 into my Jetta.
    Senior Member I4N is on a distinguished road I4N's Avatar
    Apr 2011
    With the corn.
    1,495
    Default Re: Jetta Auto to Manual Swap Question
    Yes, you can. It involves a lot of work/parts but if everything you need in the donor car works then go for it (if you get the car dirt cheap). You should be able to figure out what you need to swap out if you have knowledge of manuals. There is a few things you may not know already, the gauge cluster should also be changed out and so should the ecu. The ecu is the shitty part, I believe just having one from a manual is not enough. You'll have to bring it to your vw dealer and see if they can do a flash for your car. I'm not sure how it work's maybe someone else can chime in that knows. But that might be spendy....
    IMO if you wan't manual, just sell your car and get one... Automatics will usually sell for more anyways, you'll attract more buyers that will pay more. Manuals usually lure in the enthusiasts that want a good deal. I'd rather put all that hard work to something more useful.
    Default
    Quote Originally Posted by I4N View Post
    X2 unless you have some good reason for swapping then the easiest thing to do is just sell your car and buy a manual.
    Sent from my SGH-I897 using Tapatalk
    Senior Member Rebjetta is on a distinguished road Rebjetta's Avatar
    Aug 2011
    Easley SC
    133
    need axles , tranny , pedals etc...ecm from other car has to be immobilized for use in other vehicle.. its costly and expensive...
    it does take cubic inches and cubic dollars...when speed is the need
    Aug 2011
    Roanoke, VA
    3
    Thanks for the info guys.
    Im only paying $500 for the wrecked car.
    And the only things i'll have to buy is a Stage 2 clutch set and the driver side axle.
    As far as time goes, ill risk that one, I want the experience.
