VW Jetta MKIII/MK3: Clutch Wont Disengage!|Volkswagen Bora
Results 1 to 3 of 3
Thread: Clutch Wont Disengage!
    Senior Member VR666 is on a distinguished road VR666's Avatar
    Dec 2011
    Maryland
    129
    Default Clutch Wont Disengage!
    98' Jetta VR6 (After Market racing Clutch)
    Ive Bled the hydraulic clutch several times. The pedal Will not stop the clutch from spinning completely, but I can still shift into gears without it stalling. I can hear the clutch spinning when the engine is running. If I push the shifter lightly in any direction, the sound stops, but the sound doesn't stop when I push in the Clutch pedal. I Can't go into reverse without grinding. The Forward Gears are not grinding but they are a little difficult to get into. First gear being the hardest, every other gear is fairly easy.
    Is This a BAD CLUTCH? Slave/Master Cylinder? Shift Linkage Adjustment problem? Throwout bearing?
    Please Help.
    Dec 2011
    Maryland
    129
    Default Re: Clutch Wont Disengage!
    I Found Out My Clutch Over Center spring Fell Out Also....
    GLX Noob Reaper is on a distinguished road Reaper's Avatar
    Jan 2012
    Vancouver, WA
    30
    I have the same problem with getting into gear but Its only 1st and 3rd
    97 GLX with Bilstein front struts and KYB Rears
