VW Jetta: Fuel pump / relay problem....HELP|Forum Volkswagen Bora
Results 1 to 5 of 5
Thread: Fuel pump / relay problem....HELP
    Default Fuel pump / relay problem....HELP
    Car died on hwy last month ('01 Jetta 1.8T), did some troubleshooting, bottom line new fuel pump, same thing happened yesterday fuel pump wouldn't prime), fortunately driveway, so I changed the fuel pump relay. Still nothing...after poking around for 2 hours. I decide to check the fuel pump. DOA...bad pump I suppose, but pretty rare. The question is while I had the voltmeter hooked up to the fuel pump harness to check the voltage, I was getting a reading of 1.65 v without the ignition on. When I turned the key it jumped up to 12.4 for a few seconds then went back to 1.65. I did pull the fuel pump out and tried to jump it with a battery and got nothing, so I am getting a free one sent under warranty. Question is is that normal to show a reading with the car ignition off of 1.65v?
    JettaJunkie.com
    Advertisements
    Default
    The fuel pump prices when you open the door instead of only when you turn the key so it sounds normal that the pump would have some power with the key out of the ignition. It probably shuts off completely when you lock the car. Don't quote me on that though
    Sent from my SAMSUNG-SGH-I717 using Tapatalk
  4. #3
    Senior Member MagicGLI is on a distinguished road MagicGLI's Avatar
    Oct 2010
    Chicago, IL
    2,225
    Default
    ^^^ makes a lot of sense. I'm thinking the same way.
    Hidden Content I'm not totally useless, I can be used as a bad example...
  5. Remove Advertisements
    JettaJunkie.com
    Advertisements
  6. #4
    Jan 2010
    Rhode Island
    4,815
    Blog Entries
    1
    Default
    It shuts off after a certain amount of time once the car is off. That way it doesn't burn itself out if you make alot of quick stops
    Sent from my r00ted dr0id running MIUI
    Hidden Content Originally Posted by I4N Hidden Content
    ear sex
    RIP: 1995 black mk3
    Hidden Content
  7. #5
    Default Re: Fuel pump / relay problem....HELP
    Thanks for the responses, got the new fuel pump yesterday and she fired right up, we'll see how long this fuel pump lasts (hopefully it was just a bad pump) I did notice however that when I had disconnected the battery while changing the pump and fuel filter that when tested again with the meter after hooking up the battery, she read 0.0, so it probably does shut off after a while, just hoping it doesn't stay on and kill the pump somehow. We shall see!
