VW Jetta: 2001 VW Jetta Engine Temperature Running Hot|Forum Volkswagen Bora
Results 1 to 5 of 5
Thread: 2001 VW Jetta Engine Temperature Running Hot
    Default 2001 VW Jetta Engine Temperature Running Hot
    Hello
    I have a 2001 VW Jetta with 193,000 kms on it. I noticed when the engine was running (highway) for about half an hour, the engine temperature rose to 130 degrees and continued displaying this temperature. No warning lights on the dashboard came on. Also, when I parked the car, and turned off the engine, the fan that usually turns on when the engine is turned off did not come on.
    Does anyone know what the problem could be? And is this an expensive fix?
    Thanks so much!
    JettaJunkie.com
    Advertisements
    Default
    130 degrees? Normal operating temp for our cars is 190...
    Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
  4. #3
    Default Re: 2001 VW Jetta Engine Temperature Running Hot
    I am from Canada, and the normal operating temperature is 90 degrees, and it normally runs at 90 degrees, and now the temperature of the engine is running hotter.
    Does anyone know what the problem could be? Thanks!
  5. Remove Advertisements
    JettaJunkie.com
    Advertisements
  6. #4
    Default
    Oh think yours is in celcius that'd explain it. Well we can't just say its this and problem solved. Start checking things off. That's pretty high mileage, have you had the water pump/thermostat/timing belt done? Also check the coolant. As far as the fan not turning on IDK, could be a relay issue or the fan. If you stick your hand down and turn the fan blades you should feel ni resistance whatsoever i believe. If there's any resistance the fan needs to be replaced.
  7. #5
    Junior Member Wrenchy is on a distinguished road Wrenchy's Avatar
    Apr 2012
    Nelson BC Canada
    26
    Gooten morgan
    high mileage/? this smiling owner got a new old 92 freeby with 560kk and have been playing with the heating sequence - not sure where the that needl should go in normal- its just below verticle and take a while before thermostat opens and also low speed fan to come on
    also in bc Canader
    up the replublic- oops thats eire
