VW Jetta: Strange Engine Noise|Forum Volkswagen Bora
Results 1 to 7 of 7
Thread: Strange Engine Noise
    Default Strange Engine Noise
    Hi, I have a 2003 Jetta GLI that is making strange noises coming from the engine. The car has a little under 90k. The car has two new ignition coils, and a new water pump. Also has a new clutch. The timing chain has not been replaced, as with the serpentine belt. I can't find out what that noise is, maybe timing chain or serpentine belt? It doesnt really seem like it. Thanks for the help in advance.
    This link is a clip of the noise the car makes:
    http://youtu.be/H7LyLqGrLNU
    JettaJunkie.com
    Advertisements
    Jun 2008
    Mason City, IA
    14,451
    Default
    Hmm its a 24v and they don't really have the chain issues that 12v's do... does it get worse when accelerating?
    Sent from my DROIDX using Tapatalk 2
  4. #3
    Senior Member 0S1R1S is on a distinguished road 0S1R1S's Avatar
    May 2010
    Minnesota
    361
    Default
    Have you checked your exhaust fittings? It could be a part of your exhaust system rattling. That would also increase in intensity at higher RPMs.
    Sent from myPhone using myThumbs
  5. Remove Advertisements
    JettaJunkie.com
    Advertisements
  6. #4
    Default Re: Strange Engine Noise
    I'm not sure if gets worse when accelerating, the engine drowns out the noise. i tried revving the car in neutral and it seems like the rattling noise gets faster. Where do i check the exhaust fittings? I have never worked on vw. Usually on cars you follow the headers down to where it meets the exhaust, both attached by two bolts. Is that what i need to tighten? or something else?
  7. #5
    May 2010
    Minnesota
    361
    Default
    Let it cool off, grab hold and give it a little shake. If it moves more than you think is normal, or you notice loose bolts, there is your issue. VW bolts on exhaust systems are crap.
  8. #6
    I tried to shake it but it doesnt budge.. its completely stiff up close to the headers. nothing else seems to move more than it should, its all tight..
  9. #7
    May 2010
    Minnesota
    361
    Default
    Just a thought. Have you checked the bolts on your CV axles?
Tags for this Thread
