VW Jetta How To/DIY: DIY (mk3) 2.0 Timing belt|Forum Volkswagen Bora
Results 1 to 6 of 6
Thread: DIY (mk3) 2.0 Timing belt
    Senior Member VeeDubJetta98 is on a distinguished road VeeDubJetta98's Avatar
    Jan 2009
    Haverhill Ma 01832
    358
    Default DIY (mk3) 2.0 Timing belt
    A3 2.0 Timing Belt Install
    1996 Jetta GL The following describes the steps necessary to replace a timing belt in a 2.0 VW Engine. I have included pictures to help with the install. I recommend the purchase of a Bently Manual for this procedure, however, it is not necessary.
    First of all, you need the right tools. You will need the following:
    • 13mm box end wrench
    • 1/2" and 10mm sockets and an extension
    • Vice Grips
    • Impact Wrench 1/2" Drive
    • Metric Allen Wrenches
    • 3/4" Star shaped Socket 1/2" Drive
    • Floor jack and jackstands
    First of all - since you will be removing the serpentine belt and accesories belt, I recommend replacing these as well. Now, jack up the passenger side, secure with a good jack stand, and remove the tire. Next there is a plastic splash shield that covers the lower pulleys, remove this. At this point you will see what type of 3/4" socket you will need. Next, using you 13mm Box Wrench, loosen the adjuster nut on the power steering pump, then use your vice grips to loosen tension on the accessories v-belt and remove.
    1. Next remove your airbox, p-flo, or whatever type of filter you are using. This will make things MUCH easier. Once this is done, there are two clips on the timing belt cover. 2. Pop these (they should be easy to release) and wiggle out the cover. 3. Using the 13mm Box wrench remove the bolt on the serpentine belt tensioner and remove the tensioner, then the belt.
    1.
    2. 1. Now, using the 3/4" Socket, rotate the engine clockwise until all the TDC (top dead center) marks line up. On the cam gear you will see an OT mark as well as an OT mark on the engine block. Sorry about the poor picture, the flash flushed out the mark on the gear, but trust me, its right under that arrow.. 2. The lower pulley has a notch in it to line up with the lower cover piece you haven't removed yet. Using your impact wrench, remove the bolt from the lower pulley, and then pull off the pulley. **Note: First try removing the 3 allen head bolts (either 5mm or 8mm, I can't remember). With these off you do not need to remove the entire pulley. In the case of this car, those wouldn't budge, but I was able to remove the crank bolt. Wierd, huh?
    1.
    2.
    2.
    Next, using your 1/2" socket, 10mm Socket and Allen Wrenches, remove the bolts holding the lower belt cover on, and remove. Then using the 13mm box wrench, loosen the bolt on the timing belt tensioner and release tension to the belt. Now you can remove your old timing belt. Next you will see the distributor gear. This gear also has an OT mark on it, but don't use this one! Pull the distributor cap off and look for a notch in the housing that points roughly straight back. Make sure the rotor is pointing at this mark and you're all done! Next, install your new timing belt, and replace the lower cover.
    You are done with the hard part. Simply put everything else back together in the reverse order of disassembly. I have included the three figures that I used in the bently manual to complete this job. Enjoy and good luck!!!!
    Some newer cars have a new style timing belt tensioner, if your car has this tensioner, good luck! That thing is the biggest pile of crap I've ever seen. I ordered the parts to convert mine to the old manual adjust tensioner. MUCH easier to work with!
    -Dub
    i R luV mY VDub 2.slow
    Junior Member backsideblumkin is on a distinguished road backsideblumkin's Avatar
    May 2011
    Bellingham, Washington, United States
    7
    Default Re: DIY (mk3) 2.0 Timing belt
    wanna send me your bentley manual? =] you'd make my prego girlfriend veryy happyy. lol
    just a download,
    Senior Member 99JettaGTmk3 is on a distinguished road 99JettaGTmk3's Avatar
    Feb 2011
    Cincinnati, Ohio
    151
    Quote Originally Posted by backsideblumkin View Post
    just a download,
    omg me to !
    Junior Member ZachRabbit is on a distinguished road ZachRabbit's Avatar
    Jun 2011
    Ohio
    29
    so you don't know how to work the newer style tensioner?
    mine has that, and i don't really feel like buying the parts to convert it to the old style.
    any tips on the new style?
    Junior Member whattajetta is on a distinguished road whattajetta's Avatar
    Jul 2013
    oklahoma city
    2
    Default my own Dreaded Timing Belt Job on 90 Jetta
    thanks for the DIY guide. printed it out, my new coffee-table reading literature
    about to embark on the project.
    My belt slipped off while driving, (because?) the tensioner pulley snapped, spilling bearings etc.
    Ive been all over the web, looking for info. The guides, videos and tips I've found are specific to either MK3s (96, 98...) or MK2 diesels.
    Hopefully Ill track down my Chilton from storage, but til then I turn to internettin
    Havent read much about belt and pulley replacement specifically when they have have given out while car is driving.
    my initial questions (more to come, Im sure) are
    1. for this older car, do i also need to jack engine, remove engine mounts?
    2. i would assume the all timing marks will be off, and would maybe need a timing gun to find TDC?
    not sure if this is a non interference motor, not sure if there was valve damage, but gonna give her a try anyway
    ANY feedback welcome, thanks!!
    Jul 2013
    oklahoma city
    2
    Default Re: my own Dreaded Timing Belt Job on 90 Jetta
    oh, and also:
    what I do have as far as guides is a 77-84 Bentley.
    There is a applicable section on Camshaft Drive Belt.
    the removal/installation seems to be similar to timing belt removal. Is this the same thing?
    Do I need to remove valve cover to get to fly wheel to find those notches?
