VW Jetta MKIV/MK4: 1.8 Turbo Timing Belt Replacement |Volkswagen Bora
Results 1 to 5 of 5
Thread: 1.8 Turbo Timing Belt Replacement
    Default 1.8 Turbo Timing Belt Replacement
    How hard is it to change the timing belt on an 04 jetta 1.8 turbo
    Default
    Not too bad if youre just changing the belt but a little harder if you plan on doing the pump. The engine needs to he jacked up. The only reason most people shy away from this job is because if it isnt timed right youll bust your head.
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
    Default Re: 1.8 Turbo Timing Belt Replacement
    from what ive seen and heard its alot easier to pull the engine or have the car on a lift and drop the engine i know its tough just getting the cover off ti inspect it. but you want to replace the pump. especially if its oem, cuz it has a plastic impellar thats known for breaking. switch it out with one with a metal impellar
    not your typical air ride DasBohan is on a distinguished road DasBohan's Avatar
    Nov 2008
    Annapolis
    7,192
    Quote Originally Posted by tdbaker156 View Post
    sry but this is very wrong on the 1.8t. Its very easy and the hassle of removing the engine far outweighs the squeeze. Plenty of room with the inline 4. ECS makes great full replacement kits that include the waterpump, thermo, and water pump gasket. A lot of stuff to remove but its not an incredibly hard job for the amount of money you save. And there are great DIYs all over the web.
    All girlfriends are legal. Its just what you do with them that may be questionable lol
    Quote Originally Posted by OregonDweller View Post
    he just wants all your scene points Ryan, careful.
    Keep'em Hammered onavianva is on a distinguished road onavianva's Avatar
    Nov 2010
    Virginia Beach, VA
    856
    dasbohan is totally correct. it is not easier to removed the engine just to remove the timing belt. if that makes sense. think about it. i can assist you in pictures on how to support the engine. barney style. i just swapped my engine mounts and has to support my engine. i actually lifted the car up a little accidently from the oil pan! (oops)
    but yeah the hardest part is starting. imo. judging from the number of your posts (9) you are not ready for a timing belt replacement. but hey. you might know more than me. let me know if you need help
