VW Jetta MKV: 07 Jetta- Wiper not working! Help! |Volkswagen Bora
Results 1 to 17 of 17
Thread: 07 Jetta- Wiper not working! Help!
    Junior Member dmc07 is on a distinguished road dmc07's Avatar
    Feb 2013
    Vaughan
    19
    Default 07 Jetta- Wiper not working! Help!
    Hope someone can help! My wipers stopped working.
    2007 Jetta 2.5 (non-city)
    Front Wiper
    -All fuses are good.
    -There is power to the connector that connects to wiper motor.
    -Ground is good.
    -Tried 2 other motors and they did not work.
    -Hood switch is OK, actually disconnected it.
    -Wiper Transmission is OK (6months old)
    -Washer fluid will spray
    Not sure what else could be wrong?
    Wiper switch?
    Any help would be appreciated!
    Thx
    Doug
    Eccentric Nutjob Grease Slapper is on a distinguished road Grease Slapper's Avatar
    Dec 2012
    Crazy Town, NJ
    543
    Default Re: 07 Jetta- Wiper not working! Help!
    I would jump the motor directly from battery or if you think switch is bad jump across the switch
    Feb 2013
    Vaughan
    19
    Thanks! Newbie here. how would I jump across switch?
    Senior Member Vee Daab is on a distinguished road Vee Daab's Avatar
    Aug 2012
    California
    531
    Default
    Just hook up the motor to the battery by wire. Without anything in between to see if it operates or if it doesn't.
    2012 VW GTI 2.0T DSG Oo=\X/=oO
    Feb 2013
    Vaughan
    19
    I have not tried that, but I have tried two other motors that will not run when connected also. I was told these motors can not be bench tested, needs the switch line?
    Feb 2013
    Vaughan
    19
    Is it difficult to replace a wiper switch? Any instructions online somewhere?
    May need to take the hit and bring it into the shop. FML
    Thanks!
    Dec 2012
    Crazy Town, NJ
    543
    Quote Originally Posted by dmc07 View Post
    It can be bench tested. It has no idea if it is in the car or not. Alot of these newer components are switched on the ground side, so just hooking the hot side to power doesnt work you need to hook a ground as well
    a wiper control arm is pretty straight forward, its just plug and play. Hardest part is opening the steering column and thats not even that hard.
    Feb 2013
    Vaughan
    19
    Thank you very much for your advice and instruction!!
  9. #9
    Junior Member epson1970 is on a distinguished road epson1970's Avatar
    Feb 2013
    Montreal,Canada
    2
    i had this problem on my 2006 jetta MKV,and did all possible.than someone told me to put spray them (wiper motor treads-which are made of plastic with WD-40 spray),took an few minutes for it to remove water ,that accumulated around motor assemblies and it WORKED..works ever since,no problems..this happened 2winters ago and never failed me ,ever since...try that..is a 5$ fix,all you do is spray like mad man around where wiper motors go inside firewall...good luck & best regards from Montreal,Quebec,Canada..
  10. #10
    Feb 2013
    Montreal,Canada
    2
    i was told that is a common problem on new V generation Jettas..in weather cold,than wet snow melting to water,than cold going to it again is short time intervals,causes a icy build up and jams wiper rods,which are plastic made..spray with WD-40,wait a few minutes,it will start to work,than spray again..than will work better-faster-than spray again...it worked for me 2years ago and is no problems ever since..my VW is a 2006 Jetta ,so i a same thing as yours..i didi that after doing all typeas of tests with fuses,jumoing motor wires,etc..made me go MAD..than i called my friendly mechano ,offered him a case of MOLSON BEER and he told me that fix...good luck with it,CIAO>>
  11. #11
    Feb 2013
    Vaughan
    19
    Out of ideas. I have tried two other motors connected to car. And I have tried connecting directly to battery and motors will not run. One motor was from a working car.Thinking I am not getting the signal from the third switch wire?
    Anything else I can try?
    Dealer wants $75 for wiper switch or $110 to diagnose.
    Was hoping i could find a DIY fix! arrrrhh.
  12. #12
    Feb 2013
    Vaughan
    19
    Wipers still not working.
    Not motor, transmission, fuses, or switch.
    Any ideas?
  13. #13
    Dec 2012
    Crazy Town, NJ
    543
    Hmm theres not much left
    Is the motor receiving the proper voltage? There might be some high resistance somewhere in the lines.
    Im going to try and remember to get a wiring diagram for you car at work tomorrow. We have alldata pro. No promises because Im alittle scatterbrained sometimes.
    [/Sarcasm]
  14. #14
    Feb 2013
    Vaughan
    19
    Thank you! Thank You! Thank You!!!
  15. #15
    Feb 2013
    Vaughan
    19
    I found a relay panel behind my dash.
    Do I have a wiper pulse relay?
    Anyone have diagram that shows which relays fit each location? I only see numbers.
  16. #16
    Feb 2013
    Vaughan
    19
    Dealer scan shows :Module coding is incorrect. Needs recoding.
    What a pain in the ass!
  17. #17
    Hi I am having a very similar problem. My Mech says the problem is almost certainly Control Module, but It could also be rodent damage (outside chance) It need further diagnosing (they had only half an hour)
    Will you let me know what the result of your efforts was?
    Thanks.
