Ive got a 94 2.0 gl that does not have fog lights currently. BUT, I want to add them. Has anyone done it? is it possible? If so which ones would go best with some awesome yellow HIDs?
If your going to go with Yellows make sure you know the law about them. Where I am if you have yellow you can only use them in the heavy rain, fog, or snow. Not as extra driving lights. Aswell as to the fact that they have to switch off if you turn on your highbeams.
HID is also way to bright and expensive for lights you wont use that often. I recomend LEDs instead. I bought a set of LED lights that fit into my fogs with the same connector and base as a stock H3 bulb. They wire up the same, use way less power, and last longer. I just need a warm day to build a nice looking wireing loom for them.
Related Threads
Volkswagen Jetta Junkies
295K posts
41.3K members
Since 2007
