VW Jetta: Replace thermostat help 2004 Jetta 1.8t|Forum Volkswagen Bora
Results 1 to 8 of 8
Thread: Replace thermostat help 2004 Jetta 1.8t
    Default Replace thermostat help 2004 Jetta 1.8t
    I need to replace the thermostat on my 2004 Jetta 1.8t and have read conflicting instructions….
    Remove the alternator……Don’t remove the alternator.
    Can the thermostat be replaced without removing the alternator and, if so, what special
    instructions and / or tools are necessary?
    Thanks in advanceeveryone. Brian Bryant
    JettaJunkie.com
    Advertisements
    Junior Member CP1.8T is on a distinguished road CP1.8T's Avatar
    Jan 2013
    BC, Canada
    2
    Default Re: Replace thermostat help 2004 Jetta 1.8t
    I'm having the same issue with mine...these vids may help:
    detailed instructions...http://www.youtube.com/watch?v=zavHYU_YHEM
    coles notes...http://www.youtube.com/watch?v=_ozkgPonYDk
  4. #3
    Senior Member Bangarang1.8t is on a distinguished road Bangarang1.8t's Avatar
    Sep 2012
    Poky, Idaho
    159
    I removed the alternator seemed like the less frustrating way
  5. Remove Advertisements
    JettaJunkie.com
    Advertisements
  6. #4
    Thanks for your input. I have seen these videos. I have successfully removed my thermostat, thermostat housing and O-Ring without removing the alternator (as of 8/7/13). Whether or not I can install these remains to be seen. But it looks very likely I can do it without removing the alternator. If you would like detailed instructions (hints / tools, etc.), let me know and I will give them.
  7. #5
    Jan 2013
    BC, Canada
    2
    Hey did you end up getting everything put back together? If so can you give me some details including tools used? I found another video on a Audi forum and it looks like replacing the thermostat without removing the alternator is a much easier route.
  8. #6
    Member nickscls2 is on a distinguished road nickscls2's Avatar
    Aug 2012
    Eastern Shore
    48
    I used a 1/4'' universal joint with a 10'' extension and i got the bolts off and on pretty easily.
  9. #7
    not your typical air ride DasBohan is on a distinguished road DasBohan's Avatar
    Nov 2008
    Annapolis
    7,193
    just take out the alt, risking not getting the lower hose to tighten properly over the oring and thermostat is not worth it. Throttle body is i think only 3 5m hex bolts. Use a 5/8 wrench to pull back the tensioner and lock it. The tensioner is 4 5m hex to remove, and the alt is 2 13m bolts. its very simple. 15minute job that would bill 1.5 hr
    Hidden Content Originally Posted by Boost Addicted Hidden Content
    All girlfriends are legal. Its just what you do with them that may be questionable lol
    Hidden Content Originally Posted by OregonDweller Hidden Content
    he just wants all your scene points Ryan, careful.
  10. #8
    Yes, I removed and replaced the thermostat on my 1.8t without removing the alternator. Fairly simple now that I reflect on it. I have about a two page narrative on what I encountered and will be happy to email it to you. I think it is too long to post on this website. Email me at bbryant44@msn.com and I will forward you a copy.
