VW Jetta MKIV/MK4: AC compressor clutch not engaging |Volkswagen Bora
Results 1 to 9 of 9
Thread: AC compressor clutch not engaging
    Default AC compressor clutch not engaging
    03 jetta 1.8t checked the fusses. Radiator fans do come on when AC button is pressed. It seems to have enough pressure in system. Relays are under dash board but i do not know which one controls AC. Any help with any of this would be appreciated. Thanks
    Senior Member richie1.8TnAZ is on a distinguished road richie1.8TnAZ's Avatar
    Oct 2011
    tempe,az
    310
    Default
    From what I read there aren't any relays. Have you checked the pressure switch? The fuse panel on top of the battery also could have a bad fuse. Ive changed my fcm, pressure switch, and checked all fuses but my clutch still wouldn't engage. I tested my compressor and it seems to have a bad coil.
    Sent from my Nexus 4 using Tapatalk 2
    Default Re: AC compressor clutch not engaging
    Thanks I looked up relays for the car and VW does sell one for the AC. I thinks I will call VW and ask some questions.The fuses on the battery look fine. How did you check the compressor?
    Jan 2010
    Rhode Island
    4,815
    Blog Entries
    1
    Default
    Might be fan control module. Or just high pressure in your system. Try to recharge first
    Sent from my SGH-I997 using Tapatalk 4 Beta
    Hidden Content Originally Posted by I4N Hidden Content
    ear sex
    RIP: 1995 black mk3
    Hidden Content
    Oct 2007
    PA
    2,779
    pressure switch is an option. Have you jumped power to your compressor to make sure the compressor isnt bad? And checked for power to to compressor? Hows the charge, do you know for sure the proper amount of refrigerant is in there?
    Jan 2010
    Rhode Island
    4,815
    Blog Entries
    1
    Default
    Also spin the clutch to make sure jt moves freely
    ear sex
    RIP: 1995 black mk3
    Hidden Content
    Thanks to everyone. I will spin the clutch by hand to see whats going on. Can I simple unplug the compressor and hot wire it? I will also check the voltage I am getting to the compressor. I will let you know. Thanks Its my sons car and I don,t have access to it all the time. Between getting the secondary air pump working and the door lock unit better it seems that the AC has taken a back seat.
    Oct 2007
    PA
    2,779
    yes you can hot wire it from the battery or something and force it to engage to make sure it works.
  9. #9
    Fukenmüven great_kicker is on a distinguished road great_kicker's Avatar
    May 2008
    Kville, TN
    1,014
    i had a similar problem, i replaced the fan control module, the pressure switch, got the system recharged, no dice. Finally took it to the dealer and turns out the fuse panel on the battery had failed, the fuses were all still good, but the panel did not work any more. My engine temperature would also go way up if left the car running without it moving.
    Hidden Content ADD me
    Hidden Content
    your jetta will transform...into a transformer...and transform your ass hole into the grand canyon
