VW Jetta MKIV/MK4: Clicking noise from engine. Valve adjustment? |Volkswagen Bora
Results 1 to 11 of 11
Thread: Clicking noise from engine. Valve adjustment?
    Default Clicking noise from engine. Valve adjustment?
    Clicking noise from the engine. Sounds like it needs a valve adjustment. I couldn't find any info here about valve adjustments on a VR6 (2000). I'm not familiar with the internal workings of the VR6. Might it need a valve adjustment or could this be something else?
    2000 Jetta VR6
    - New radiator
    - New temp sensor
    - coolant boiling over (fixed)
    PROBLEMS
    - acceleration power issue (bad cat? fuel filter? slipping clutch?)
    Default Re: Clicking noise from engine. Valve adjustment?
    Valve tick is normal on these cars, more so than Hondas, Toyotas, Fords, etc. Well... The Ford Focus has some loud tick lol, but check your oil, make sure its full. Otherwise, as long as the car is running well, valves should be fine...
    Jun 2008
    Mason City, IA
    14,452
    When does the ticking start? Certain RPM's? How many miles are on your VR6? It's most likely either your timing chains or your intake shifter rod.
    May 2009
    Iowa
    431
    Fords have a very noticalbe tick to them. It is not valve noise it is the injectors clicking that most people hear.
    Quote Originally Posted by Vixen View Post
    It's pretty constant and hardly noticeable when I'm in the drivers seat. However, it's loud enough when I open the hood that it draws concern. I'm at about 115K miles.
    2000 Jetta VR6
    - New radiator
    - New temp sensor
    PROBLEMS
    Its probably injector solenoid click, like Green was talking about with Fords.
    Senior Member vr king13 is on a distinguished road vr king13's Avatar
    Sep 2009
    Ocean City NJ
    239
    valve tik is normal, for loss of power chek out the MAF, and check the thermostat if that not bad chek the over flow hose for clogs.
    Jun 2008
    Mason City, IA
    14,452
    Well if you haven't gotten your timing chains does it's most likely that. They're supposed to be done at 100k and they can get pretty fcukin' loud when they're bad. Go on youtube and type in vr6 timing chain noise and see if it's the same sound.
  9. #9
    You can call me God Nicholai is on a distinguished road Nicholai's Avatar
    Jul 2009
    Ponchatoula, LA
    719
    Mine has a ticking noise as well. Can't hear it in the drivers seat but when the hoods open it's very distinct. Thats at idle rpm's (800 or so). My dad told me not to worry about and thinks I'm paranoid about my car.. lol
    Still havn't gotten my timing belt changed.... pushing 115k miles now I know I'm horrible....
  10. #10
    Sep 2009
    Ocean City NJ
    239
    after i did my chains and guides engine still tiked then i new cams, lifters, and tighter springs tthhheenn the tik went away! But normal were and tere the tik will b fine. if u hear a rappping grinding noise then the giudes r shot
  11. #11
    Jun 2008
    Mason City, IA
    14,452
    What RPM is it most noticable?
