VW Jetta: Replacing The Stock Speakers|Forum Volkswagen Bora
Results 1 to 12 of 12
Thread: Replacing The Stock Speakers
    Default Replacing The Stock Speakers
    Hey my friend has a 2001 mk4 and he wants to boost his soundsystem but doesn't want to really go through the trouble of adding additional speakers, so he wants to replace the stock speakers with higher quality ones, we've got a friend whos real good with wiring and all that but not sure where to get the speakers or even what kind. My other friend has a pioneer sub and that sounds great so we were thinking of getting him those if he can afford it.
    My real quesiton is can this be done? can we just rip out his old speakers and place in ones of similar size.
    JettaJunkie.com
    Advertisements
    Senior Member jetta,man12 is on a distinguished road jetta,man12's Avatar
    Dec 2009
    san diego
    172
    Default Re: Replacing The Stock Speakers
    if you want it to like nice you would have to take door panels off. heres the link have fun
    http://forums.vwvortex.com/zerothread?id=961163
    2004 Jetta GLS 1.8t
    Kyowa Racing rims
    2 12'' RockFord Fosgate P1s
    300 watt Rockford Fosgate amp
    Kenwood door speakers and tweeters
    Pioneer deck
    Blacked out tails
    More to come Hidden Content
  4. #3
    Marine MonkUSMC is on a distinguished road MonkUSMC's Avatar
    Aug 2009
    Long Island, NY
    285
    My friend was looking into changing my speakers, and searched around and found out that the MK4's speakers are welded into the door panels. I can't confirm this, but that might be something to look for, before doing all this.
  5. Remove Advertisements
    JettaJunkie.com
    Advertisements
  6. #4
    Jetta TDI Str8whiteboi is on a distinguished road Str8whiteboi's Avatar
    Sep 2008
    New Mexico
    2,109
    I changed all of my speakers in my 2001 TDI when I was putting my system in and it was really simple. If I were you I would go on crutchfield.com and look on there. They will tell you what fits where and when you order from them they also give you a booklet on how to do everything. And MonkUSMC the speakers are not bolted into the door there is little metal tips that you can easily tap out with a small screw driver and a hammer. It took about an hour to do them all with taking everything off and put them back on.
    Shawn
    step one: slam it
    step two: make a sandwich
    pötHoLe crew.
  7. #5
    JettaJunkie Infant..lol SC2.0 is on a distinguished road SC2.0's Avatar
    Jan 2009
    Prince Edward Island, Canada
    2,608
    they is pop-rivited in i believe. i want RockFord Fosgate T162's for my doors but dunno if they fit. i know you can get them 6.5" which the stocks are
    EDIT: i change those to these http://www.crutchfield.com/p_575R165...653.html?tp=95 haha
  8. #6
    Sep 2008
    New Mexico
    2,109
    Yeah that's what they are but there easy to get out. I don't have any pictures of mine but it was really simple.
    Shawn
    step one: slam it
    pötHoLe crew.
  9. #7
    Fukenmüven great_kicker is on a distinguished road great_kicker's Avatar
    May 2008
    Kville, TN
    1,014
    Yeah the factory speakers are riveted in, and yes they are 6.5''. the factory speakers can be removed with a drill and or a hammer and chisel/punch. the problem that you will encounter with flush mounting new speakers in the factory location is the gap that will be left from the factory speakers between the door itself and the panel. I would suggest doing something along the lines of what i did to help channel the sound waves into the car instead of into the door panel (i have pictures below). What I did, is bought some insulation foam from walmart. it needs to be a pretty dense foam in order to withstand temperature changes and vibrations. the foam i used is found in the heater/fan section of walmart the dimensions of it was like 2''x2''x a couple feet. I cut them in half along the length of it so that it was 1''x2''x however long it was. I cut the individual lengths needed to go around the speaker, and glued it down with a silicone adhesive. You will probably need to use duck tape or something like that in order to hold the foam in a circle while the silicone sets. I also drilled holes into the factory grills and pop riveted the grilles from the new ones to them, for purely aesthetic purposes.
    Hidden Content ADD me
    Hidden Content
    your jetta will transform...into a transformer...and transform your ass hole into the grand canyon
  10. #8
    Sep 2008
    New Mexico
    2,109
    That's a really good idea lol. I saw you put the aftermarket speaker protecters in. I kept mine stock just to keep them flush.
    Shawn
    step one: slam it
    pötHoLe crew.
  11. #9
    Jun 2008
    Mason City, IA
    14,451
    Why not just look for the monsoon system?
  12. #10
    I did some research for you and your buddy and this is what crutchfield.com suggested for a 2001 VW Jetta.
    http://www.crutchfield.com/g_400/All...ckford+Fosgate
  13. #11
    Alright its good to hear that its not too too difficult to get the speakers in.
    He wants to get some pretty good speakers, we were actually gonna go with alpines but on crutchfield they didn't have any 6.5s only .75s so hes gonna prolly go with those pioneers
    that vwvortex link is gonna really help with the door disassemble thanks.
    i think he might order those speakers soon and then were gonna try and do it in our friends shop cause its heated in there, hopefully we'll be able to get all 4 doors done away with in a couple hours.
  14. #12
    May 2008
    Kville, TN
    1,014
    i have eclipse ones in my car i like them pretty well
    Hidden Content
