VW Jetta MKIV/MK4: 1999.5 jetta check engine light help p1565 and p1580 |Volkswagen Bora
Results 1 to 3 of 3
Thread: 1999.5 jetta check engine light help p1565 and p1580
    Default 1999.5 jetta check engine light help p1565 and p1580
    I have a jetta with codes p1565 and p1580. I dont know what to do, i have replaced the tb, mafs, and cleaned everything. Still same codes.
    I did notice if u start it and clear the codes the light wont turn back on till the car is shut off and then started back up. The p1565 code comes on before the p1580
    What can i do or what can i try, i am open to anything that could work
    Default Re: 1999.5 jetta check engine light help p1565 and p1580
    Did you ever manage to solve this?? I'm having the exact same issue, and am banging my head against the wall as to what to do!!
    Does anyone have a SOLUTION?
    Please help!!!
    The codes appear to be involving your throttle actuator. The solutions I found would be to clean your TB, but if you completely replaced it I am not sure. This may or may not fix the light, but it for sure will not harm your car, and will make it run better even if it does nothing to help this particular issue...seafoam your car. Worth a shot right? You might be surprised.
