VW Jetta: 2001 TDI won't start|Forum Volkswagen Bora
Results 1 to 3 of 3
Thread: 2001 TDI won't start
    Default 2001 TDI won't start
    Hit something and cracked the oil pan. I assume that the oil pressure switch made the car beep 3 times and shut down as the oil level went down. Hauled the car home, replaced the oil pan, pressure switch and car just cranks. Replaced the M109 relay, Crank position sensor, checked injectors and had fuel, checked the timing, checked compression and ran the VAGCOM system diagnostics with no codes or issues. Car still won't start. Any ideas before it goes to the bone yard?
    Senior Member PowerslavePA is on a distinguished road PowerslavePA's Avatar
    Sep 2014
    Nazi Germany, Apparently.
    851
    Default Re: 2001 TDI won't start
    Diesel is compression ignition, hence no spark plugs. If fuel is getting into the
    cylinders, it will start. You can have fuel at the injectors, but if they don't
    open, you don't get fuel into the chambers.
    Did you disconnect and reconnect the battery at all? If not try that.
    The oil light will flash and you'll get beeping again when the car keeps cranking
    but won't start.
    This is a common issue, and no definitive answers.
    Tried disconnecting the battery but that didn't work either.
