2011 VW Jetta MK6/MKVI: P2181 code 2014 jetta|Volkswagen Bora
Results 1 to 16 of 16
Thread: P2181 code 2014 jetta
    Default P2181 code 2014 jetta
    Just got the car and as you can see already having trouble. So I'm driving to work on the expressway and all of a sudden check engine light turns on. No big deal I thought so I go get it scanned code p2181 comes out cooling system performance. They ask if I have ran the car hot and I'm like no I just got it. Plus how can I tell also if there's no temperature gauge. So we reset it and all is good until today again I'm going to work and turns on again. Have any of you had this happen especially with a practically new car. The car has 76,+miles.
    Sent from my SM-G935T using Tapatalk
    Default Re: P2181 code 2014 jetta
    So we got some cold weather here last night and I turn on the heater on the car. And I wait 10-15mins to warm up and I take off. As I'm driving home I realize that it never got warm inside. So I'm guessing maybe the thermostat is stuck open. Again I'm just guessing. Have any of had this problem. Could it be related to the 2181 code that came on. Like I said it's a 2014 jetta s model. Is to soon for this to happen
    Sep 2014
    Nazi Germany, Apparently.
    849
    Low Coolant level
    Faulty Engine Coolant Temperature Sensor
    Stuck or leaking thermostat
    Engine Coolant Temperature Sensor harness is open or shorted
    Engine Coolant Temperature Sensor circuit poor electrical connection
    If the thermostat is letting coolant by, the temperature is not "operating temperature"
    and will set the warning. If it were sticking closed, you'd get the overheating MIL on
    the dash, they don't have one for LOW temperature, so the CEL comes on instead. So,
    if you have no heat, then it's running too cold, thus a performance issue. You are also
    using more fuel cold, which is also a performance issue. No heat is a sign the thermostat
    is stuck open. The only other reason is clogged heater core.
    I have a diesel, so I have an electric aux heater that is on till the engine warms up.
    Let's hope it's the thermostat cause like I said I reset it and the next day it came back on and it's a 10-15min drive from home to work. And the overheating lighting doesn't come on. So my bet would be the thermostat is open like you stated. I looked for a thermostat at autozone and O'Reillyauto but looks like they don't carry it for this year. So I called the dealership and it cost close to 70 dollars. Would you happen to have a website maybe get the same for lower price?
    Sep 2014
    849
    http://www.keffervwparts.com/a/Volks...P/F50D030.html
    Shows just the thermostat for $22.50. and even with the housing, is
    still under $40.00 for both, but cheaper on eBay:
    http://www.ebay.com/sch/i.html?_from...1113C&_sacat=0
    Should I risk ordering it from ebay. I have bought parts from there but never for an import this will be a first. But thank you for the links really appreciate it
    Sep 2014
    849
    I got all of my replacement parts for my 2103 TDI on ebay. Everything except the Hood (amazon)
    was undamaged. Even the replacement hood was damaged. They refunded me the money, and I
    was able to keep both hoods. I can bend out the metal to look presentable, not perfect.
    I just got my LH fender brace, and painted it today. Mine is actually not bent as much as I
    thought it was seeing the new one. Still, didn't want to bother trying to pull it out. After painting,
    it looks perfect.
    Just waiting for the LH bumper cover bracket that bolts on to the brace, and I will be able to start
    putting my car back together.
    Guess I'll be ordering soon from either sites you provided. Is it a hassle to get this done on this cars. Like I said this is my first vw vehicle. Also can you direct me in the direction of doing led conversion in and out. I don't really know if these came stock for the license plate lights but mine came with what looks oem leds for the plates.
  9. #9
    Sep 2014
    849
    These cars are temperamental with LEDs. I was able to do the City lights, and side
    markers without setting the bulb-out MIL. When I put LEDs in the tails, I get the MIL
    for a bad bulb.
    PLATE lights, work fine also. Make sure the lights are OFF when you pull the plate housings, they
    will short to the trunk metal and blow the fuse., Turn the lights off, take them out and let them
    hang. Remove the incandescent bulbs, then turn the lights on. One at a time, place the
    LED in till it lights up, then you know you got the right polarity. When both are done, turn the lights
    off. Then put the housings back in the trunk lid, then turn the lights on to verify. If you can find
    good COB style paddle lights to fit in, use those. Using LEDs with a half round lens at the top
    does not give enough light unless you can find the phillips ones, not the Sylvania, they are not
    bright enough. Use ones like this for the plate lights:
    They have to be good ones, I bought TEN of them from China, they burned out within weeks.
    Interior, also fine, but you'll see the LEDs will be on VERY VERY LOW when you turn the
    car off. Also fine, that current is there with regular bulbs too, just not enough to illuminate
    them where as LEDs are low power, and they do stay lit, but very very low. Does not drain
    the battery.
    You need GOOD LEDs, not cheap Chinese ones that cost next to nothing; they stop
    working or start flickering within a few months.
    Do not use H7 LEDs as your LOW beams, and if you do for highs, get the brightest
    ones you can, GOOD brand name expensive ones...
  10. #10
    Cool thanks I'll take all these info into consideration. The plate already had leds I'm assuming it came stock
  11. #11
    Sep 2014
    849
    As far as I know, they're not stock, unless they're the ones with the LED panels in them.
    If they have LED wedge bulbs in it, then they were put in there. Stock ones are hard-wired
    LED panels, and you can't replace the LEDs, you would need the whole assembly. You got the
    car used, right? Anyhow, you can buy that, starting at $15.99 for the assemblies with LED
    panels in them: http://www.ebay.com/itm/Error-Free-L...-/121377661204
    Did not find any OEM ones with LEDs...
    This is what the stock 2011-2014 ones looks like, and they come with incandescent bulbs:
    The Hybrids will have LEDs from the factory.
  12. #12
    I'll take a picture of it wen there's light but it doesn't look like led wedge bulbs but it's all good saves me some money
  13. #13
    Here's a picture of the license plate it has the vw logo so I'm guessing it is stock
  14. #14
    Sep 2014
    849
    Yeah, it's stock... Gotta see if the chick across the street, who got a 2014, has
    LED plate lights. Heh, maybe swap them out when she's not looking, ha ha ha ha..
    She always liked mine, so she got a 2014.
  15. #15
    Haha you should give a try just tell her that hers aren't good n your switching them out lol
  16. #16
    Haven't updated this yet but it turns out it was the thermostat that made the light come on and good thing cause last week we dropped down to the high 30s. For some it's whatever but for us down south way south of Texas it's cold for us. But since they changed the thermostat the heater works great now. Weather down here is crazy one day its hot the next cold and so on lol.
