VW Jetta MKIV/MK4: remote start help needed |Volkswagen Bora
Results 1 to 11 of 11
Thread: remote start help needed
    Default remote start help needed
    My daughter has an 02 Jetta 1.8T automatic. Tried getting a remote start installed. Most places I tried said they will not do VW`s. So looks like I will be doing it my self . My plan is to use a viper 3305V and a 556UW bypass. Can any one advise me if there is a better way to do this ? and if so what would you suggest ? Also any one know what problems I'm likely to run into ? she wants this for Christmas so any help before I order parts would be appreciated .
    Default Re: remote start help needed
    2002 Volkswagen Jetta Remote Vehicle Start Wiring:
    Vehicle Battery Positive Wire (+): White/Red
    Vehicle Battery Positive Wire Location: Ignition Switch Harness
    Vehicle Ignition Wire (+): Black
    Vehicle Ignition Wire Location: Ignition Switch Harness
    Vehicle Second Ignition Wire (+): Brown/Red
    Vehicle Second Ignition Wire Location: Ignition Switch Harness
    Vehicle Accessory Wire (+): Black/Red
    Vehicle Accessory Wire Location: Ignition Switch Harness
    Vehicle Second Accessory Wire (+): N/A
    Vehicle Second Accessory Wire Location: N/A
    Automobile Engine Starter Wire (+): Red/Black
    Automobile Engine Starter Wire Location: Ignition Switch Harness
    Automobile Second Engine Starter Wire (-): N/A
    Automobile Second Engine Starter Wire Location: N/A
    Factory Anti-Theft System: Volkswagen Transponder Vehicle Immobilizer
    Factory Anti-Theft System Type: Key Sends a RF Signal to the BCM Module
    Crankshaft Sensor Wire: N/A
    Crankshaft Sensor Wire Location: N/A
    Camshaft Sensor Wire: N/A
    Camshaft Sensor Wire Location: N/A
    Car Key Sense Wire (-): Brown/Red
    Car Key Sense Wire Location: Ignition Switch Harness
    Car Neutral Safety Wire (+): N/A
    Car Neutral Safety Wire Location: N/A
    Car Tachometer Wire (-): Green/Yellow
    Car Tachometer Wire Location: At Instrument Cluster
    Car Speed Sense Wire: White/Blue
    Car Speed Sense Wire Location: At 3 Wire Plug at Driver Side of Firewall Coming from Transaxle
    Car Parking Lights Wire (+): Gray/Brown and Gray/Violet
    Car Parking Lights Wire Location: At Vehicle Light Switch
    Car Brake Lights Wire (+): Red/Black
    Car Brake Lights Wire Location: At Switch Above the Brake Pedal
    Car Reverse Lights Wire (+): Black/Blue
    Car Reverse Lights Wire Location: At Harness in Driver Side Kick Panel
    Car Horn Wire (-): Black/Yellow
    Car Horn Wire Location: In Harness at Steering Column
    PAC Immo Adapter - Equivalent to OLMDBALL
    https://www.carid.com/2002-volkswage...-16828949.html
    Here is someone who put in a Python:
    http://forums.vwvortex.com/showthread.php?3917413
    Lot a work, which is probably why no one will do it.
    that wiring diagram I'm sure will be worth its weight in gold . thank you so much . but I get lost when it comes to the PAC Immo Adapter . I have read the write up the guy did on his python install. but he used a 556uw . people say those do not work well on vw`s and the new way to do it is with the PAC. but I am also told it has to be programed by some one licensed to install them and has the computer to talk to the car. If I buy that pac unit can I program it my self some how ? or could you help me understand how to use it ?
    BTW her Jetta already has a factory alarm. And I'm not looking to add a lot of bells and whistles. All I want to add is remote start and keyless entry so some how I think I need to tie into the existing alarm .
    could any one tell me what 2 wires on the viper 5303 alarm I use to tie into the existing factory alarm and where on the car they are ?
    You don't have an install manual for the Viper? You'll have to go to their web site
    and see if you can find it, or search Yahoo or Google for it. If you mean CAR
    side, there aren't any. It's all immobilizer.
    Jan 2013
    NV
    2,942
    Nov 2009
    Bear, DE
    13,380
    alright guys, let's calm it down, keep it on topic or its gonna get locked up, Powerslave you do come off as arrogant at times, let's just cool it down and help a guy out trying to do a remote start install
    OP I'm gonna tell you to proceed with caution, I'm currently watching a remote start horror story in the shop it's a different model but it's a remote start horror story
  9. #9
    I agree. Im trying hard to be daddy of the year by getting this thing in before Christmas. I have it all installed . every thing I wanted to work does. IE lock unlock, remote start, but for some reason I can start it several times no problem . then try it one more time and the stater doesn't disengage and I have to hit the brake to stop it . but with all the hassle in here I don't think its worth asking.
  10. #10
    Quote Originally Posted by Skimmer0220 View Post
    Not my fault people can't read... Do arrogant people actually take the time to
    read the posts to get a grip? No, the ARROGANT people don't read, and repeat
    what others have already done. THAT, is arrogance... Or, if you want to call
    them morons, whichever works, as either one works for me...
  11. #11
    The starter not disengaging after several uses, has to be a logic issue, or a latched
    relay. If it were hooked up wrong, it would do it all the time. Make sure the TAC wire
    has a solid connection. Vibrations can momentarily break contact with the wire if
    not secured. Solder your "Y"ed off wire to the tac signal wire, and to a female spade
    connector, then use a hooded male connector to prevent shorts to ground
    with vibrations, and what have you.
    I believe there is also an option to start without a TAC wire, by setting a crank time
    to from 1 -4 seconds. Carburetor engines need longer crank times, FI does not. Like,
    with my 2006 HHR, I can nudge it to start, and immediately let go, the engine continues
    to crank till started, and the key is in RUN while it's cranking, pretty neat.
    So, a 1-second crank time would be all I need. So, if all fails try forgoing the TAC wire,
    and use the timed crank option. If that still gives you the same problem, contact VIPER
    support, they do go bad and have intermittent issues. I have seen it personally. The
    only units I installed were Viper.
