VW Jetta MKIV/MK4: Struts and shocks |Volkswagen Bora
Results 1 to 6 of 6
Thread: Struts and shocks
    Default Struts and shocks
    What all should be replaced when changing shocks and struts ? What would be the part numbers for ordering ? 2001 jetta 1.8 l turbo aww.
    Jan 2013
    NV
    3,016
    Default Re: Struts and shocks
    Front strut mount and bearing. (Part numbers are in the link)
    http://www.germanautoparts.com/Volks...spension/198/6
    Rear mount.
    http://www.germanautoparts.com/Volks...uspension/31/4
    Sep 2014
    Nazi Germany, Apparently.
    851
    You won't need the rear upper shock mount unless yours are shot, check them
    before replacing.
    I found a complete front "Easy Strut" kit on eBay for $189, that has everything
    already assembled, with the upper mount and bearing & cap. I have yet to
    install them.. I also have rear shocks, I need to put on as well...
    Jan 2013
    NV
    3,016
    I'm providing another link to a kit, in case the OP doesn't want to use/trust EBay. You OK with that Mr. Slave?
    http://www.germanautoparts.com/Volks...spension/472/9
    Sep 2014
    851
    Quick Struts:
    http://www.ebay.com/itm/99-05-Volksw...-/291146948611
    http://www.ebay.com/itm/Pair-New-Dur...-/122247920559
    Just examples of what I was referring to, fully assembled, no spring compressor needed.
    Mine are SAID to have a lifetime warranty, yeah, as long as they're in business I suppose.
    For yours for $109, can't go too wrong for two complete struts.
    Nov 2009
    Bear, DE
    13,461
    just an FYI if the suspension is stock you will need a spring compressor to remove the old assembly unless you remove the ball joint, tie rod, and axle also axle nuts are torque to yield nuts and an alignment will most likely be needed to be done after an install if most all these components are removed
