VW Jetta MKIV/MK4: I need help with a recurring issue!! |Volkswagen Bora
Results 1 to 7 of 7
Thread: I need help with a recurring issue!!
    Unhappy I need help with a recurring issue!!
    Hey Jetta Junkie! Long time lurker seeking some help finally Welp, the problem is that my Traction control light likes to stay on alot, It'll come off every now and then when I start and drive the car, But after a couple quick drives, It'll turn on and stay on. The big problem is when i'll be driving and my brake light (parking brake) and airbag light.... will flash for a second and make 3 beeps followed by my car driving horrible.. Loss of power and torque.
    Here are the fault codes:
    OBDeleven data log
    Date: 2017-01-10 19:49
    VIN: 3VWSE69M15M035781
    Car: Volkswagen Jetta
    Year: 2005
    Mileage: 164860 KM
    01 Engine Control Module 1
    System description: 1.8L R4/5VT G 0030
    Software number: 06A906032SL
    Coding: 07550
    Trouble codes:
    No trouble codes found
    02 Transmission Control Module
    System description: AG5 Getriebe 09A 0237
    Software number: 09A927750BD
    Trouble codes:
    01314 - Engine control module (ECM) No communication
    Intermittent
    01316 - Brake control module No communication
    Intermittent
    03 Brakes 1
    System description: ESP FRONT MK60
    Software version: 0102
    Hardware number: 1C0907379M
    Coding: 0019970
    Trouble codes:
    00778 - Steering angle sensor No signal/communication
    static
    08 Air Conditioning
    09 Central Electrics
    15 Airbag
    System description: 04 AIRBAG VW61 0202 0003
    Software number: 1C0909605F
    Coding: 12340
    Trouble codes:
    16 Steering Column Electronics
    17 Dash Board
    System description: KOMBI+WEGFAHRSP VDO V57
    Software number: 1J5920926H
    Coding: 15230
    Trouble codes:
    01304 - Radio No communication
    static
    19 Gateway
    System description: Gateway K<->CAN 0001
    Software number: 6N0909901
    Coding: 00006
    Trouble codes:
    static
    00778 - Steering angle sensor No communication
    static
    22 All Wheel Control
    25 Immobilizer
    System description: Adresse 17 eingeben
    Software number: Bitte
    Trouble codes:
    29 Light Control Left
    35 Central Locking Control Module
    36 Seat Adjustment Driver Side
    37 Navigation
    39 Light Control Right
    46 Central Module Comfort System
    System description: 1H Komfortgerát HLO 0004
    Software number: 1C0959799C
    Coding: 00258
    Trouble codes:
    00928 - Lock unit for central locking Driver side Implausible signal
    static
    47 Sound System
    55 Headlight Regulation
    56 Radio
    57 TV Tuner
    75 Telematics Communication Unit
    76 Parking Assistance
    PLEASE PLEASE PLEASE HELP!! Maybe something to do with the ecm
    Nov 2009
    Bear, DE
    13,443
    Default Re: I need help with a recurring issue!!
    sounds like it could be a ground issue, I would pull up the rain tray and take a look at your grounds, clean them up put some electrical grease in there and reattach them
    I agree with checking for bad grounds. Check also battery terminal connections and maybe have the battery load tested. Low battery voltage will cause lots of electrical problems. Should always be above 12.6v
    Quote Originally Posted by Skimmer0220 View Post
    Thanks for the reply! Where exactly are the ground locations, sorry I'm not so sure.
    Nov 2009
    Bear, DE
    13,443
    Quote Originally Posted by Dommodus View Post
    Inside of the rain tray is 2 grounds, I'm not sure if both the grounds here tie into the ecu if not both at least one does, there is also multiple grounds under neath the battery tray
    I would also check the ecu relay just to be sure the connectors are not corroded.
    Default
    Okay so I cleaned all the grounds and the problems are still occuring. I'm going to test the battery load and hopefully that will work
