2011 VW Jetta MK6/MKVI: Massive coolant leak|Volkswagen Bora
Results 1 to 2 of 2
Thread: Massive coolant leak
    Junior Member sdfinley is on a distinguished road sdfinley's Avatar
    Apr 2017
    Houston, TX
    4
    Default Massive coolant leak
    Hi all, first post here. I have a 2002 Jetta 2.0 5 speed wagon. I bought it used 3 years ago and supposedly it had a new water pump and timing belt installed a few months before I bought it. Yesterday when I drove to work (approx 11 miles) as soon as I pulled in a parking spot my low coolant light started to flash. Popped the hood and the reservoir was almost empty. I got it home last night, had to fill up the reservoir to make it. I have it jacked up in the driveway and it appears to be leaking from the bottom belt pulley on the passenger side of the car. I took the TB cover off and the belt is dry. The leaking is pretty heavy when I remove the reservoir cap. When I start the engine it doesn't leak at all when idling or when parked.I have done quite a bit of searching but cannot find a definite answer on this. Could it be the WP cover? Is there a way to remove the pulley to get a better look? I am somewhat mechanically inclined, and have a buddy that can help me out. I have attached a photo, please excuse my paintbrush skills. The red arrow is pointing to a water droplet. Thanks all!! Oops wrong jetta forum. please move to the mk4
    Attached Thumbnails Attached Thumbnails Click image for larger version
Name:	vw coolant leak1.jpg‎
    Last edited by sdfinley; 04-19-2017 at 02:43 PM. Reason: please delete I posted in correct forum
    Default Re: Massive coolant leak
    Looks like weep hole, more than likely it's your water pump, imo.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
