VW Jetta MKIV/MK4: Need help Car is dead , and needs to be resurrected. |Volkswagen Bora
Results 1 to 6 of 6
Thread: Need help Car is dead , and needs to be resurrected.
    Default Need help Car is dead , and needs to be resurrected.
    Car died at a parking lot, it's an 04 bbw engine code. Scanner showed crank and cam sensors. Replaced them, and still no go. Anything else I should check?
  2. #2
    Senior Member KiDGiB is on a distinguished road KiDGiB's Avatar
    Jan 2013
    NV
    3,016
    Default Re: Need help Car is dead , and needs to be resurrected.
    Check compression, make sure there's fuel and spark.
  3. #3
    Default
    Spark is there, I will check with vagcom, for fuel, a simple gauge to the rail? What psi should it be at.
  4. #4
    Default
    I have spark and fuel. Still same codes. Can someone point me to where I may find the timing marks. Belt looks good, but might just change it since it's at 98k
  5. #5
    Jan 2013
    NV
    3,016
    Here's a discussion on it. If you have the Bentley, it will show what you need to do.
    http://forums.vwvortex.com/showthrea...-timing-issues
  6. #6
    Default
    While looking for the timming marks, I noticed the cam would not move. Looks like the belt got stripped at the crank. FML.
