VW Volkswagen keyless entry flip key remote users guide
VW sidewinder flip key application 1998 to 2009
Volkswagen does not have a comprehensive application guide or chart. Nor is their part application of these remotes complete or specific.
Short version:
1998-1999 New Beetle: any HAA key works, 3 button remote = 1J0959753F and 1J0959753T, no immobilizer system
1998 to 2001 Passat: any HAA Key works, 3 button remote 1J0959753F (E = wagon) and 1J0959753T (S = wagon), no immobilizer system
1999 1/2 Golf & Jetta: any HAA key works, 3 button remote = 1J0959753F and 1J0959753T. no immobilizer system
2000 to 2001 Golf & Jetta: any HAA key with rfid chip works, 3 button remote = 1J0959753F and 1J0959753T. yes, immobilizer system
2002 to 2005 New Beetle, Passat, Golf, Jetta: any HAA key with rfid chip works, remote= 1J0959753AM or DC . yes, immobilizer system
2005.5 to 2007 Golf, Jetta; newer HAA key 1T0, remote= 1K0959753H, yes, immobilizer system
2005.5 to 2010 New Beetle; newer HAA key 1T0, remote= 1J0959753AM or DC, yes, immobilizer system
Volkswagens security key system is like the old bug with the cart in front of the horse, you program the car to the key, not the key to the car.
2008 and 2009 are VW dealer only keys, cars are too new, keys have different frequencies and chips than the older cars.
Programing the button REMOTE portion of the key is simple.
You do need 2 keys. You must be able to lock the drivers door and have the red led alarm light next to the lock button blink. If it does not blink, the alarm does not know the door is closed and will not go into program mode. Put one key in the ignition switch, turn on, do not start engine. Close the door, use 2nd key, turn door lock and hold in lock position for 10 seconds. Release key to neutral position.
Press a button on the remote, within 2 seconds press the same button again, the turn signal lights will flash,
this indicates your remote matches the car system and is now recognized. Unlock door remove key from ignition.
So don't pay extra 99 cents to $5 for these instructions in hopes of getting the KEY to function with the car.
Instructions are only for the keyless remote, not the key.
The HAA keys are cut by using your serial number to the car (vin dependent) There is a 4 digit key code, unless you are the original owner or you have the black zip tie tag that was attached to the black valet key, you will not have the key code. We use an image of the key cut to verify the code to be cut.
Applications contained here-in are for the Volkswagens in North America. Volkswagen has 7 markets worldwide. Due to frequency licensing in different countries the remotes will have other part numbers similar to USA. Example, the oval 2 button E and the 3 button F in Europe are G and H. Asia uses A and B. They are not interchangeable between countries.
Starting in 1998 with the New Beetle 98-99 and Passat 1998 to 2001.5 (01 Passat serial number 49999 or less), with the Golf IV and Jetta IV 1999.5, the key does not have a computer chip, and does not need the engine computer programed to recognize it. The remote has the oval button HLO 1J0 959 753 F . The remote does not have the chrome bar on the end, only the corner loop to attach to a key ring. This remote will not work with 2002 and newer Volkswagens.
Now available is this vintage look key for the cars without the immobilizer systems or to use as a hide-a-key or emergency key to gain entry to the car if you locked your other keys inside.
Original 1J0959753F application 08/97 to 05/99 do not have transponder computer chip for 06/99 to 05/01 and newer Volkswagens that require one. 1998 and early 1999 cars had banjo Hella remotes. The F and T flip key 3 button remotes ( E and S are 2 button for the wagon) will work with these cars. Replacement 1J0959753F (and E) all have transponder chips. See date codes marked after the part number on the button remote portion of the key. 34/98 = week 34 of 1998
If you have the oval button remote and the batteries keep going dead or with new batteries it won't work. The button gets distorted and keeps the switch under the button pressed, killing the battery. This also prevents it from being programmed. You may have to match the remote to the car if the batteries have been dead too long.
Some models, the transition date is different, look for the yellow car with the key under it when you turn the ignition on.
(second light from the left)
Will not do Cabrio, Eurovan or 2005.5 up cars.
key tag that came with the valet / mechanics key.
1J0959753T ( S is the 2 button) original application 10/00 to 05/01 but will work from 08/97 (new beetle) 1999.5 to 05/01 Golf, Jetta, Passat (original may look like F with oval button) Only 1 out of 3 oval button remotes have the transponder chip because only 1 out of 3 are the T version. Even with the chip, a used flip key head cannot be made to start the immobilizer cars unless the chip is new. The chip is a one time use device. Once matched to a car, it belongs to that car.
1J0959753AM original application 06/2001 to 2005 New Beetle, Golf, Jetta, Passat but will not work on 05/2001 and older cars. Note: AM and DC will work with Eurovan 2001-2004 and will need to be recognized by engine computer.
In 2000 model year (around May 1999) the transition takes place with immobilizer 2, (immo II) the addition of a writable computer chip inside the key portion of the flip key. 2001 is a transition year. The remote changes to the squared buttons but the frequency of the button remote is the same as the older Volkswagens with the oval buttons. This remote will work on the older cars but not the newer cars. HLO 1J0 959 753 T (wagon 2 button is S) It can be programmed to the engine computer but not to the keyless entry of 2002 (May 2001) and newer Volkswagens. It has the newer look with the chrome bar on the end.
Starting late in 2001(June) to 2005 the squared button remote has a more common part number HLO 1J0 959 753 AM (replaced by 1J0959753DC). This remote has a different frequency matched only to Golf IV Jetta IV Passat and New Beetle. It has the chrome bar and a computer chip. You can buy the Vagtacho software from me and do it with your laptop or you will need a VW dealer or Automotive Locksmith to program the engine computer to recognize the key. After the key is cut, it will work in the locks, start the engine, but the engine will shut off as a theft prevention if the engine computer has not been programed to recognize it. This key will work in 2000 and older Volkswagens but the 3 button remote will not. It has a different frequency. Works with Eurovan 2001-2004. This key also works on 2006 TDI Jetta (December 2005) since the diesel production was ending they installed the older keyless systems. Check your remote to match part number.
