VW Jetta How To/DIY: Where is coolant leaking??|Forum Volkswagen Bora
Results 1 to 17 of 17
Thread: Where is coolant leaking??
    Junior Member paulga is on a distinguished road paulga's Avatar
    May 2010
    WA
    28
    Default Where is coolant leaking??
    I noticed red coolant drippings on ground on the driver side. I went down the car and found this:
    I see dripping on the lower radiator hose. But where is it leaking from??
    another view:
    Maybe it's because of the curb... that day I didn't apply the parking brake tough enough when we left the car (on a slope).. The gravity showed itself when we were going home. So both of us were seated, and I shifted the gear to neutral preparing to start the engine. But then the car slipped forward on the curb.. And the car was barred by the curb so I was not able to back the car. Some people came and help trying to lift the front end a little bit while I giving gas to back up..
    Come to think of it, maybe one of the pipes were damaged at that time. Does it have something to do with the thermostat and/or housing, crack pipe..?
    I'm going to replace these things next week. It's too bad if they're actually not the source of leakage.
    Jul 2009
    PA
    2,922
    Default Re: Where is coolant leaking??
    looks like your thermostat neck is crack from the pic.
    theres no thermostat neck in pic?
    well im 99% sure it wont be ur thermostate pipe...obviously if u hit something ur radiator would get damaged/cracked and not ur thermostat housing because that is connected to ur engine followed by a rubber hose..unless its cracked of natural cause.....dont worry about it..take off ur bumper and all the fun stuff behind it for abetter view...i couldnt see where mine was leaking until i uncovered it
    radiator + coolant under 200$ =] have fun
    Jul 2009
    PA
    2,922
    Quote Originally Posted by jedduh View Post
    this is what i meant. http://www.urotuning.com/shop/coolin...18t-p-949.html
    May 2010
    WA
    28
    Thanks men.
    @TurboJettaBoy02:
    do you mean this hose circled with yellow brush?
    I dont know the name of that but someone told me it's the lower radiator hose. also mine is a VR6 gls, not a 1.8T. Yes there're drippings on it, but it does not guarantee this hose is source of leakage, right?
    @jedduh:
    I'm trying to analyze it... with the iron thing circled with red brush barred by the curb, I have to give more gas engaging the clutch more to back up. Finally I backed up, but apparently something is messed up. As I remember, the driver side outer grille was popped out.. The tab on it was damaged so I had to order a new one.
    Well, maybe that iron thing also damaged the radiator, or just the lower radiator hose, maybe and/or top /bottom hose. How do you determine if the radiator is leaking or if a hose is leaking for sure(suppose front bumper and lock assembly moved out of way)? so that I dont need to order all possible parts.
    Thanks.
    Jul 2009
    PA
    2,922
    easy thing to do it wipe everything dry from b4. jack the front end up and look to see where it starts leaking, after u start the car. then just check the hose or whatever, if u cant see the whole thing, probly take it off and look it over. just make sure u only USE G12 coolant and not anythin else. vw's cooling system will corrode with other coolants.
    May 2010
    WA
    28
    Quote Originally Posted by TurboJettaBoy02 View Post
    The problem is to take off the lock assembly requires draining the coolant. It's definitely a messy one. I probably need to change the radiator. I have the illustration, but haven't found where it is. It's said to connect to the lock assembly(lock carrier and metal bumper). Probably the radiator was damaged due to the strain of the bottom metal part of the lock carrier because of the barring of the curb..
    Visiting Old Volks Home Elrodg is on a distinguished road Elrodg's Avatar
    May 2010
    Murray, KY
    150
    well first off def wipe everything down. but don't jacck it up because it will move the air bubble in your radiator. leave everything on the ground and find the highest point that you can that has coolant dripping. ur car will have to be hot of course. Radiator coolant leaves behind a trail. it could be a pin sized hole in your radiator and it will show a spot where the paint is eaten away by coolant. which if that is the case get some bars leaks and put a bit of that in your radiator.I've even used pepper before to stop a leak. when your stuck on the side of the highway you get a little creative. (I've even heard of ppl using an egg white.)
    If all the world is a stage, I wanna operate the trapdoor.
    99 Jetta GLS 5 speed LOADED
    84 VW Vanagon 5 speed 1.9 wasserboxxer AKA "Lunchbox"
  9. #9
    May 2010
    WA
    28
    Thanks that makes sense. but could you explain what you heard using a white egg(?) when sticking on the side of highway?
    I'll only remove the font bumper and inspect the radiator.
    Maybe there's a permanent strain caused shape-change in the radiator core support, in which case the damaged support need to be changed too.
    but if you don't take the lock assembly down how can you inspect both sides of the radiator?
    to disconnect the lock assembly means to disconnect lower and upper radiator hose, and thus to drain the coolant.. so the engine should be cool?right?
  10. #10
    May 2010
    Murray, KY
    150
    Quote Originally Posted by paulga View Post
    to stop a leak in a radiator.... use pepper.... and I've heard that if you put an egg white in your radiator it will stop a leak
  11. #11
    May 2010
    Murray, KY
    150
    Quote Originally Posted by Elrodg View Post
    continued from above: you are making things WAY too complicated here you are looking for a leak not structural damage. it's gonna be something simple. a dry rotted hose, crack in a fitting something like that. you are not gonna hurt the frame unless you hit that curb at 30 mph
  12. #12
    May 2010
    WA
    28
    I think you're right. though I don't know how to apply pepper to stop coolant leakage. not to mention egg white.
    If the problem lies solely in a damaged radiator, it's actually easier than the case thermostat, thermostat housing, a/c switch, crack pipe ..need to be replaced. I'll look for a DIY on how to replace the radiator then perform it. It's not creative.. and a radiator is $$$. but any job related to the cooling system is always messy, say, the coolant has to be drained from underneath the car.
  13. #13
    Senior Member Jspoolin2001 is on a distinguished road Jspoolin2001's Avatar
    Mar 2009
    Northern New York
    472
    The pepper trick is simple, you just put it in the top of the radiator, not the reservoir. Sprinkle some in it, someone should verify this for me but its that simple. But there is no way that you could have damaged your radiator by running a curb with the bumper. Have you had your water pump changed? Maybe its something with the waterpump gasket or the plastic impeller.
    I dont know about the VRs but i know the 1.8T has a circulatory pump that runs after you shut the car off to circulate coolant, and that will leak everywhere if that gets bad, it basically pisses it out wherever it springs a leak. That pump is just inside the bay right behind the radior. Basically in line with the left side of the grill.
    I had a crap tone of coolant issues with my jet, but none of them were out of the ordinary. I just dont forsee that you could do damage by hitting a curb if you only rolled into it, if you were moving pretty good, like across a parking lot and banged into one then maybe. And as they said the other thing could possibly be dryrot.
    2002 Jetta 1.8T
  14. #14
    May 2010
    WA
    28
    The pudding is only on the driver side. so I thought it was the thermostat, etc.
    but the leakage starts two weeks after that running over the curb.. the lock carrier can pop left outer grille out, it might simultaneously damage the radiator..
    I got to remove the front bumper and take a look.
    btw, do you mean the after-run pump? vr6 should also have one. whenever I shut down the engine, I could hear the coolant is flowing, some fan-like thing is still working.
  15. #15
    Just had the same problem...coolant level popped up and i was low, so i bought some coolant and when i got home i noticed drips hitting below my driver side. I tried going under but couldnt find the source of the leak...
  16. #16
    May 2010
    WA
    28
    Wink Re: Where is coolant leaking??
    Quote Originally Posted by VR6_Phenom View Post
    coolant level popped up? you saw coolant level indicator with alarm tones?
    that picture posted a year ago corresponds to a rapture in the upper rad nozzle neck.. if you observe exactly the same scene as in the photo, and drippings under the front end, check the rad, hose, gaskets areas.
    if drippings are further towards rear end of car, then thermostat housing flange.
    i just know these. the story on your car might be different. good luck~
  17. #17
    Jun 2008
    Mason City, IA
    14,452
    How many miles are on your car? I would check your tstat + housing, as well as the crack pipe. These are the most common causes of coolant leakage on the driver's side on VR's.
