VW Jetta MKIII/MK3: School Me On Transmission Fluid Replacement|Volkswagen Bora
Results 1 to 10 of 10
Thread: School Me On Transmission Fluid Replacement
    Member elicit4orce is on a distinguished road elicit4orce's Avatar
    Sep 2009
    Elmhurst,N.Y.
    93
    Exclamation School Me On Transmission Fluid Replacement
    Hello everyone!
    I wanted to get opinions on different MK3 owners/repair men on transmission fluid replacement. I called my local VW dealership to find out a price range on this type of maintenance (which comes out to be around 600 bucks in total). The Rep. warned me that High Mileage VW cars are not recommended to change/replace fluids because there is a chance of transmission "slip" happening afterward...
    Has anyone done a fluid replacement without any problems? any places that is recommended in NY (Preferable in Queens or near by boroughs) by you fine people?
    I am somewhat handy with Jetta's ... I just might not have the time to do it because of work. If the price is still around the 600's, i might as well take 2 good days off and just do it because my acceleration "hesitates" and i beleive the transmission fluid is the culprit (or atleast i might as well try that first).
    If you have any informative links that is "DIY," I would appreciate it!
    Thanks my fella Junkies!
    -Christian L.
    not your typical air ride DasBohan is on a distinguished road DasBohan's Avatar
    Nov 2008
    Annapolis
    7,193
    Default Re: School Me On Transmission Fluid Replacement
    Quote Originally Posted by elicit4orce View Post
    Hello everyone!
    -Christian L.
    Just searched transmission fluid on vwvortex heres all that popped up, see if you can find something in these couple pages:
    http://forums.vwvortex.com/search.php?searchid=1375765
    All girlfriends are legal. Its just what you do with them that may be questionable lol
    Quote Originally Posted by OregonDweller View Post
    he just wants all your scene points Ryan, careful.
    Sep 2009
    Elmhurst,N.Y.
    93
    It said no matches...i also looked further into that website, just my luck...the transmission section shoes a 404 Error.
    Nov 2008
    Annapolis
    7,193
    go to the search engine on vwvortex in the forum section. Go to advanced search. Set it to search titles only and type in transmission fluid, theyre like, 4 pages of info.
    Sep 2009
    Elmhurst,N.Y.
    93
    Awesome, You are the man!
    here is the link... http://www.blauparts.com/vw/vw_fluid...nsmissionfluid
    Now i need to find out which fluid is compatible with my 97 2.0L jetta GLS Automatic Tranny.
    500 bucks saved, thanks! i will post if my cars feels a lot better in the future.
    Senior Member JDM_GUY is on a distinguished road JDM_GUY's Avatar
    May 2010
    San Francisco Ca
    984
    id suggest you buyin the fluids from the dealership or even go to local car parts store and find a compatible/similar automatic tranny fluid, just do the work your self if your mechanically inclined. dont forget to buy the tranny gasket and the filter while your at it. good luck
    Sep 2009
    Elmhurst,N.Y.
    93
    I believe i found the specific fluid plus KIT that will be compatible with my 97 2.0 Jetta GLS.
    http://www.blauparts.com/proddetail.asp?prod=F2A1012-C
    i will definitely need the luck and can't wait to get started. = )
    Sep 2009
    Elmhurst,N.Y.
    93
    **UPDATE**
    I did the whole change today... I must say it was the best investment i have done (worth the time and patience).
    I got excited when i received my package with the Blauparts ATF Kit. I printed out an extra DIY instructions along with my VW Manual and instructions from Blauparts (every kit comes with instructions, awesome). It took me about 2.5 hours since i have never done it before, similar to changing motor oil except need a good level base for proper drainage. Anyway, once i was done with the ATF replacement. Girlfriend took me for a ride on the jetta to see if there was any difference...I have never felt our jetta ride so smoothly (wow). There was actually less noise during idling and while driving coming from the Auto transmission. No "hesitation/slips" going uphill or on the beginning of quick acceleration from a green light. Extremely happy that i saved money in my pocket. My next kit will be the Timing Belt replacement which is $110 bucks and it comes with new water pump and pulleys (WHAT!). Need to pick which day i have off...
  9. #9
    May 2010
    San Francisco Ca
    984
    congrats on the hard work of being a grease monkey for that matter . timing belt is some what cruicial so becareful on doing that your self. if you decide to do that, make sure everything is aligned such as timing marks, and make sure to remember all the things removed and put back the right way. hats off to you and good luck on the next mission.
    I never had an automatic vehicle through my whole life, im used to just changing tranny gear fluid on manuals.
  10. #10
    Jan 2010
    Rhode Island
    4,815
    Blog Entries
    1
    i changed mine with just dot4 shit and it works fine. and timing belt is easy on mk3s. even if the timing is off, its way easy to fix. Mine was off real bad, then i just poped in a new distributor and changed the timing in about 30 minutes for everything.
    Quote Originally Posted by I4N View Post
    ear sex
    RIP: 1995 black mk3
    build thread
