Hello again. Its sad to have departed from my KooLWHHIP but I'm happy with my new replacement. Say hello to my Audi
My Swaggin Wagon....
2001 Audi A4 B5 Avant Quattro 1.8T
Ebony Pearl
Automatic 5-speed Trans w/ Tiptronic (R)
Celebration Package -
*Power glass sunroof
*Homelink Remote
*Auto Dimming Inside - outside mirrors
*Perforated Leatherette Seat Upholstery
Retail: $29,915.00
Exterior upgrades
Clear side markers
Clear Headlights
De-badged
Sticker on back window
Thule Roof rack cross bars and pads
Rear Fog Lights Both
Wheels and Suspension
17" B6 Light Gunmetal Sport Package wheels
Brand new NEXAN5000 60k P225/50R17
Zimmerman Cross Drilled Slotted Rotors
New Pads
Technical
- 1.8 liter, 170 hp DOHC Turbo Charged 4 cylinder, electronic turbo boost regulation, 5 valves per cylinder
- ABS 5.3
- Quattro permanent all-wheel drive system with EDL (Electronic Differential Lock)
- Four link front suspension, stabilizer bars, front and rear
- Fully galvanized sheetmetal
Engine mods
ECS Reinforced Silicone Breather Hose Kit AWM
*Valve Cover Breather Hose - (06B 103 221P)
*Check Valve to Intake Manifold Hose - (058 103 221E)
*T-Hose - (06A 103 247)
*Block Breather Tube - (06A 103 213F)
*Valve Cover Breather tube - (06B 103 213G)
*034 Motorsport Billet PCV Valve - (035 103 245A)
Polished Intake
Polished valve cover
New Coil packs
Interior mods
6 disk changer
Checkered rear view mirror
Expandable Ski rack in rear seat
20% Polarized Tint on all windows front, back and sides
On the way...
-ECS Magnetic Oil Pan Drain Plug $15
-ECS Magnetic Transmission Drain Pug $20
-Timing Belt/Water Pump/Thermostat/Lightweight Crank Pulley/Belts
-Wheels (secret squirrel)*they are machined*
-Aluminum Mirror Caps
-Headliner
-Seats, carpet, door cards, dash...
When I first brought her home:
Now I just need the sticker to go with this.
What is going on now:
So two days after I bought her I noticed that I was hearing a bit of abnormal chatter about a quarter of a mile away from the house while getting gas. After researching I found that these years of audi like to build a bit of sludge in the motor and the oil pick-up tube gets full of sludge and the top of the motor get oil starved. This was not good. After limping it home and the dash screaming at me (the pixels on the heads up display are only read by a psychic on account they are FUBAR) I had some friends come over to drop the oil pan to clean out the pick-up tube and to see about this sludge. Long story...
After about 10 hours in the dark and cold putting everything back together she wouldn't start. Found the codes and fixed the problems but by that time the damage was done. I did however replace all of the hoses with a silicone hoses, replace all coils, spark plugs, new oil, a few vacuum lines and some other things in forgetting. Well upon taking the valve cover off I realized from the lack of oil that the cam and cam caps were all burnt up and turned the metal black; as well as the chain tensioner was all melted beyond repair so new motor.
The start of the tear down.
Pulling apart the headlight lenses to take out the gross orange reflectors. FIY These were a pain to take apart. Not sure if I'm going to color match these or not.
Ill get some more pics up later. Photobucket was being a pain.
Ebony Pearl
*Homelink Remote
Retail: $29,915.00
Exterior upgrades
Clear side markers
Clear Headlights
De-badged
New Pads
Technical
- ABS 5.3
Engine mods
Polished Intake
New Coil packs
Interior mods
6 disk changer
On the way...
-Headliner
